I have a second generation IPad using Idj pro. the new update just downloaded and I can’t hear my music thru the speakers, search bar disappears, lost all my history in djay 2. Have a huge party this Friday. What am I supposed to do?
We are already aware of some performance bugs in the latest update but we’re already working on a fix for these bugs.
There will be another update before christmas!
We’re very sorry for the inconvenience and kindly ask for patience in the meantime!
@DougDj Dbchill Byas: You can find your history by opening the library and tapping the current library icon to choose the library.
Best regards,
Lukas
Purchase Serato and a controller. Soon Serato will integrate with Pulselocker and music libraries will be able to be accessed offline. Algoriddim does not respond to these posts… Sorry to say, you’re on your own until they decide to fix a flaw. You won’t hear anything from them about the issue or an update… Really sad.
Trust you find a solution my friend.
The Serato/Pulselocker integration will allow DJ’s to legally play music for commercial purposes. Sooner or later, Spotify artists are going to find out about their music being monetized through Spotify by DJ’s without them being compensated and Algoriddim is going to be toast. Make a move now and don’t wait for the inevitable my friend…
Good luck.
You might want to check out the review by Phil Morse from Digital DJ Tips on the NEW dJay Pro release and read the comments.
http://www.digitaldjtips.com/2015/12/…
