📣 ANNOUNCEMENT: Algoriddim Launches djay App on Meta Quest
Hi everyone,
We’re excited to announce a groundbreaking update: the djay app is now available on Meta Quest, bringing an entirely new level of DJing to the virtual world! With djay on Meta Quest, you can now merge physical DJ gear with virtual controls, creating an immersive experience that’s set to revolutionize the art of DJing.
Key Features of djay on Meta Quest:
  • Mixed Reality Mode: Blend physical and virtual worlds for a performance that’s more immersive than ever. DJs can control virtual decks with hand gestures and engage with audiences like never before.
  • Professional Audio Performance: The app delivers low-latency, multi-channel sound and supports USB MIDI controllers via plug-and-play for seamless audio precision.
  • Vast Music Library: Access over 5,000 free songs and stream millions more from Apple Music, djay music, and more – all available right from your Meta Quest headset.
  • Intuitive Controls: Hand gesture support and immersive 3D turntables make it easy for beginners and pros alike to dive into DJing.
  • Stunning Environments: Perform in incredible venues like a Volcano, Space, Arena, and more, with visuals that react to your music in real-time.
djay for Meta Quest is available on the Meta Horizon Store for $19.99 and is compatible with Meta Quest 2, Meta Quest Pro, Meta Quest 3, and Meta Quest 3S.
Links to Learn More:
Let us know your thoughts, and get ready to elevate your DJ game in VR! :headphone:
Very cool :smiley:
Are more controller going to be supported than the one you have listed here? →
I’m missing support for the Denon Prime Go - will it be added at some point?
Also, what does the * symbol after some controller names indicate? There is no explanation for the * from what I can see.
Hopefully they will add more controllers. I was disappointed to not see the Rev5 on the list.
Yes that’s a strange one considering duel usb c ports.
Is the Quest application bundled with the “DJay Pro” license?
“The PRO subscription allows you to use djay across Mac, PC, iPhone, iPad, Android, and Vision Pro.” Does that count the Quest as an android or is a separate license required?
Lol, I refunded my purchase of the Quest app immediately when I saw that on your home page, cuz if it’s covered, I’m gonna get the Pro license instead.
Hi @DanderB, djay for Quest is a separate one time purchase on the Meta store for $19.99US. It is not part of the cross platform djay Pro subscription.
Is this the the announcement Algoriddim has been teasing us with? Rather disappointing for the average user of the software i imagine… but it got some potential down the road i guess.
Please focus on getting us more controller support, Soundswitch or other dmx integration and easier sync of music across platforms and devices.
Hey, I’m wondering about accessibility for those of us that have sight issues/blind?
Algoriddim have been outstanding in their efforts so far with regards to making the core software accessible on Mac and IOS.
I’m aware that Apple have done a lot of heavy lifting in that regard as they have a screen reader built into the operating system and I’m not sure if Meta have that in the Quest or not.
Any info on this side of things would be great. Cheers…
Okey I will take that update like a good indication but. I don’t think so your are looking in right direction. My opinion is like long time user we need some improvements like resizing the app like (Luma Fusion), remote control like (Filmic pro remote), more options for customisation playlists, change UI experience, ability to record and use some parts from song to used in sampler and pads for more creativity like this function in AlfaTheta GRV6.
Hi @Tessel, please see below:
https://www.algoriddim.com/hardware#quest
ESKEi83 full Meta Quest live performance:
ESKEi83 Interview
How come the S3 (with 2 channels) but not the S2. Would the midi mapping not be similar?
I got some questions…
  • I didn’t see any headphones /cueing system (nor on-ear monitoring). Was he only beat cutting between track using Fx / crabbing on the Xfader?
  • how long was the set? how did the Quest3 manage with battery life, given it was running cameras in Passthru mode?
  • was the lighting in the club fine for hand tracking?
Hi @dirrogate, I don’t have all the answers as, unfortunately, I was not in attendance.
  1. I’m not sure, but I suspect he mixed visually with the waveforms since he was probably very familiar with the tracks - he likely produced many of them himself. Also, you can actually pre-cue in the Quest headset. With a DJ controller connected you can connect headphones to the controller for pre-cueing as well.
  2. I’m guessing it was about an hour. The Quest is actually being charged via the USB-C connection to the Reloop Mixon 8 Pro, so no issues with battery life.
  3. I haven’t tested this myself, but I’ve heard the hand tracking does surprisingly well in low-ish light. If you’re using a connected DJ controller, hand tracking will be less essential.
I hope that helps!
Oh! This is great info (point 2).Thamks so much, Slak_Jaw.
I do know about the pre cueing (via the controller; headset cueing might not technically work, I’d assume, given club sound levels)
but he wasn’t wearing any headphones, so I guess yeah, he was visually cueing based on waveform.
many thanks.
You’re welcome @dirrogate
