Introducing OneLibrary and Next-Generation CDJ Integration
This major update, developed in collaboration with AlphaTheta, introduces OneLibrary – a unified music library format that lets you seamlessly transfer your playlists, cue points, loops, and beat grids across devices. Simply connect a USB drive to access your library in djay on desktop and mobile, as well as on supported CDJs and other DJ gear.
OneLibrary Integration
- Added support for USB libraries using the new OneLibrary format, developed with AlphaTheta
- Compatible with CDJ-3000X, CDJ-3000, XDJ-AZ, OPUS-QUAD, and OMNIS-DUO (requires updated firmware)
- Seamlessly export and access playlists, cue points, loops, and beat grids across devices*
- New USB Library source in djay for browsing, editing, and managing exported playlists directly from connected drives (exporting/editing supported on macOS and Windows)
- For more info please refer to the linked FAQ
Hardware Integrations
- Added native plug-and-play support for CDJ-3000X and XDJ-1000MK2 (macOS, Windows), and DDJ-XP1
- Added support for CDJ-3000, CDJ-2000NXS2, CDJ-2000NXS, CDJ-2000, CDJ-900NXS, CDJ-900, CDJ-850, CDJ-400, CDJ-350, XDJ-1000, and XDJ-700 (Windows)
- CDJ-3000X (requires updated firmware): full native integration with deck control, waveform display, and track browsing (macOS, Windows)
- RANE SEVENTY-TWO: native integration with display support (macOS, Windows, iOS)
- RANE ONE, ONE MKII, PERFORMER: added motor-off support
- RANE PERFORMER: added detailed beat-grid waveforms (macOS, Windows)
- DDJ-FLX10: added “PAD INFO” feature
- Improved Pro DJ Link with DJM-900NXS2 and added current-song key index for CDJ-2000NXS2 (macOS)
Streaming Integrations
- Added Beatport and Beatsource integration on Arm-based Windows devices including Copilot+ PCs
User Interface & macOS Enhancements
- Enhanced for macOS 26 “Tahoe” with a refreshed, modernized interface
- Added support for sorting the media library by two columns (hold Shift/Cmd when clicking the second header). MacOS only.
- Persist column-sort options between searches (macOS)
- Improved beat-grid editing UI and workflow
Audio, FX, and Neural Mix
- Added 4% and 6% pitch-fader range options
- Gate Instant FX now processed pre-fader for tighter control
DVS and Motorized Controllers
- Added option to disable waveform scaling with pitch
- Added MIDI actions to switch control modes and improve slip-mode behavior
- Improved beat-sync accuracy and “BPM only” tempo linking
- Applied pitch-fader adjustments to platter speed; improved pitch bend and instant-start stability
Automix, MIDI, and Media Library
- Improved error handling in Automix when tracks are unavailable
- Added option to import entire folders of tracks from the Files app (iOS)
- Added new MIDI actions: “Toggle Cue Point Range” and bounce-loop routing
Other Improvements
- Fixed track-title display in 4-deck mode (iPhone)
- Various performance improvements
NOTICE / REMINDER:
- Just a friendly reminder everyone.
- If you encounter any bugs, issues or have a detailed question about this release, please do NOT post them here because they could get lost in this general discussion.
- Please post them in an existing related topic or create a new topic if necessary so we can have a focused discussion there and don’t miss anything important.
