Hello everyone! Weāre excited to share our latest djay update. It should be rolling out to the various apps stores in the next 24-48 hours. Thanks!
NEW:
Added support for Reloop PTB-2 portable DJ mixer
Added screen support for Pioneer DJ XDJ-RX3 (macOS, Windows)
Added MIDI actions to move a track from deck 1/2 to 3/4
Added MIDI actions to stop recording and load on deck
IMPROVEMENTS & FIXES:
Improved instant double to copy sync state
Fixed OneLibrary export of hot cue colors
Fixed OneLibrary missing some cue points at beginning of MP3 files
Fixed slip mode when playing in reverse
Fixed dragging tracks from My Collection into other apps sometimes not working (macOS)
Fixed artwork and track number columns not allowing to be reordered (Windows)
Fixed searching media library using e.g. Japanese and Chinese keyboards (Android)
CDJ: populate missing sync slave BPM field on CDJ-2000NXS2 and newer models (macOS, Windows)
CDJ: fixed jog mode lighting up incorrectly with Pro DJ Link (macOS, Windows)
CDJ: fixed Pro DJ Link connection issues when changing MIDI configuration of mixer (macOS, Windows)
DDJ-FLX10: improved splitting/doubling stems
DJM-S11: mapped deck move actions
NOTICE / REMINDER:
Just a friendly reminder everyone.
If you encounter any bugs, issues or have a detailed question about this release, please do NOT post them here because they could get lost in this general discussion.
Please post them in an existing related topic or create a new topic if necessary so we can have a focused discussion there and donāt miss anything important.
@Mister_Tuur this does pretty much exactly what it says. If you are recording something in djay, when you press the button mapped to āStop Recording and Load on Deck 1ā, it will do exactly that. Maybe you want to quickly record a loop from the song or mix you are currently playing and drop it onto another deck. Iām sure there a many creative uses for thisā¦
