Hello everyone! We’re happy to share our latest djay update. It should be rolling out to the various apps stores in the next 24-48 hours.
NEW:
RANE System One integration, including native display support (requires Engine OS 5.2.0) (macOS, Windows, iOS)
Hercules DJControl T10 native support (macOS, Windows, iOS).
All-new desktop experience for Googlebook and Chromebook devices (Android)
Added MIDI actions to change beat jump duration
IMPROVED/FIXED:
Improved media library playlist presentation on CDJs (macOS, Windows)
Improved support for 45 RPM with motorized controllers
Improved cue point jumping on motorized controllers while scratching and during platter spin-down
Fixed toggling reverse playback with motorized controllers affecting pitch
Fixed Explorer source not showing BPM tags from files (Windows)
NOTICE / REMINDER:
Just a friendly reminder everyone.
If you encounter any bugs, issues or have a detailed question about this release, please do NOT post them here because they could get lost in this general discussion.
Please post them in an existing related topic or create a new topic if necessary so we can have a focused discussion there and don’t miss anything important.
We confirmed with RANE that the System One Engine OS update (v5.2.0) should already be available inside the unit as an over-the-air update. They are working on updating their website with the download and release notes as well.
If you select the Rane SYSTEM ONE in the dropdown menu, you should be able to access the v5.2.0 download:
I updated djay to 5.6.9 and RS1 EngineOS to 5.2.0, however Djay isn’t recognizing the RS1 and I’m not able to see or select Djay under the RS1’s source menu.
Anyone know if there are any new mappings for the playlist buttons that are on the Rane One that will be available to everyone else? I mean the 3 (A,B,C) playlist buttons that are on the top right of the jogwheel, which would automatically take you to a pre-assigned playlist.
I’m a little jealous now since I’ve got the Rane Performer. An Ipad with that would be great, but I’m aware of the practicalities. Good work though.
Hi @echa0361, from my research, it doesn’t appear that ChromeOS Flex supports the Play Store. If this is true, then djay won’t be supported as it requires access to the Play Store.
@Slak_Jaw I bought my license via Microsoft Store. I have 2 questions 1) how can I find my current version (‘About’ in settings shows a lot of infor but not the app version - why??) and 2) how do updates work? Are they pushed or do I need to check myself?
