đź“Ł ANNOUNCEMENT: djay Pro v5.0 Updates for Mac, iOS, and Windows [Changelog]
Hi everyone, we’re happy to announce some great new updates to djay Pro v5.0 for Mac, iOS, and Windows. Take a look at our changelog below for more information. Happy mixing!
Mac and iOS
v5.0.2
  • Added mappable MIDI actions for Crossfader FX
  • Improved effect tail when releasing FX pad
  • Fixed Automix incorrectly loading new song on inactive deck when manually moving crossfader
  • Fixed sync disengaging when skipping backwards
  • Fixed possible offset when doing multiple beat jumps
  • Fixed “Drum Swap” Crossfader FX when Neural Mix EQ is active
  • Various bugfixes and improvements
v5.0.1
  • Improved VoiceOver accessibility
  • Improved beat jump and loop behavior when beat grid contains tempo changes
  • Improved sync behavior when ending a scratch
  • Fixed beat grid edits not being applied to same song on other deck
  • Fixed missing pitch fader UI feedback when using MIDI pickup mode (iOS only)
  • Fixed stability issues on macOS 10.15
Windows
v5.0.6283.0
  • New: Fluid Beatgrid™ – all-new, groundbreaking beat detection engine with support for tempo changes, automatic flexible grids, and so much more
  • New: Crossfader Fusion™ – elevate your mix and apply creative effects as you transition between tracks
  • Improved settings organization and added option to deactivate loop when jumping outside of loop
  • Fixed case where Sync wouldn’t match the beat grid
  • Fixed cue point quantization sometimes being applied incorrectly
  • Fixed DVS calibration not opening on some device
Fantastic. Now you guys and gals really need to work on hardware integration. Get that sorted and you’ll have many new users I am sure, professional, serous hobbyists, mobile and home djs.
