Hi everyone,
We’re thrilled to share the latest version of djay, v5.2.8 (5.2.11173.0 on Windows), which includes many user-requested improvements! Please see the changelog listed below for more information.
NEW
• Introducing Neural Mix™ on Android: isolate vocals, beats, and instruments of songs*
• Seamless integration with the all-new Hercules DJControl Mix Ultra controller
IMPROVED
• Added ability to connect to Bluetooth MIDI controllers directly from djay’s main dashboard menu (iOS, Android)
• Added ability to show and configure MIDI controllers from djay’s main dashboard menu (iOS, Android)
• Improved Neural Mix quality and performance on older devices (iOS)
• Improved VoiceOver accessibility of sampler and track context menus (iOS, macOS)
• Optimized Match header layout in the media library for more efficient use of space (iOS)
FIXED
• Fixed some Crossfader FX breaking vocal bounce loops
• Fixed state when Censor Instant FX reaches beginning of track
• Fixed vocal routed bounce loops not being activated while some Crossfader FX are active
• Fixed cursor sometimes jumping out of the search field unexpectedly (macOS)
• Fixed Ableton Link not finding other devices on macOS 15 (macOS)
• Fixed playlist source list font size being reset when changing dark/light mode (macOS)
• Various fixes and improvements
* Neural Mix on Android requires a 64-bit CPU (used by most devices on the market).
