On Oct 17, 2015 at 01:10AM CEST Cedric Green wrote:
HOW ABOUT LIKE ON SAMPLE FFECTS WITH THE 12 SOUND EFFECTS FOR SAMPLE PACKS AND OWN PRESETS CAN THERE BE 12 INDIVIDUAL VOLUMES FOR EACH .THE THING IS ! THERE ARE SOME SOUND EFFECTS THAT PLAYS LOWER THEN OTHERS OR TOO LOUD OVER THE MUSIC . THE SOUND WOULD HAVE TO BE RE SAMPLED BY EAR ADJUSTING THE VOLUME MANUALLY TO EACH ONE AND IT WILL STILL BE TOO LOW OR TOO LOUD OVER MUSIC PLAYING .COULD YOU MAKE IT WHERE EACH SAMPLE HAS ITS OWN VOLUME ,AND MAYBE EQ , SPEED AND EFFECT LIKE FLANG,ECHO,REVERS OR SOMETHING TO ELIMINATE RE SAMPLING IN OWN PRESETS ANS SAMPLE PACKS. LETS MAKE IT HAPPEN FOR THE NEXT UPGRADE VERSION OF DJAY PRO , PS - AND ALSO HOW ABOUT MAKING THE Z KEY TO SHIFT TO THE OTHER 6 SOUNDS TO ASSIGN TO THE X,C,V,B,N,M, SOUND KEYS ON THE KEYBOARD WOULD BE MORE THEN PRO FOR DJAY .THANKS FOR GIVING THIS SOME ATTENTION AND HOPE IT MAY HAPPEN. YOURS TRUELY - DJ DEF JAMS OF HOUSTON TEXAS .
[[62cdd08d0a0df2fd556e828c020a42150778c5d5-552775559]]
