Any way to trigger the Tools Menu via MIDI?
I am currently using my phone as my laptop is dying.
The app works flawlessly on my iPhone 17 but as you can imagine the screen real estate is pretty small.
Is there any way to trigger this secondary menu via midi?
At the moment I am just leaving it open all the time.
Hi @RoscoeH, yes, you can easily MIDI map a Toggle Button for this.
  1. Open the MIDI Learn Tool
  2. Press an unused button on your DJ Controller
  3. Set the Target → General
  4. Set the Action → Toggle Tools
I hope that helps!
