Hi @hardbea7, can you please try to capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
I had the same issue and have the same software. There was a significant delay even just hitting the hot cues. I tried to clean the computer memory and changed some settings. Improved a little, but the issue occasionally appears
