App support for latest iPad Pro 11 inch
My App does not completely fill in the screen and is shifted to the left. Is there a need for an update for the new iPad 11 inch or is there something I need to do in settings? tried uninstalling and reinstalling, didn’t help. thanks
Great, thank you
I see the latest update shifted the app to the middle instead of off to the left, appreciate that, but will it not be updated to use the full real estate of the new 11inch screen? Hope to see that, what does it look like for the 12 inch iPad Pro? Do they have the same issue?
Hi Fsant,
Thank you for your post. We are aware of this issue and are providing a fix as fast as possible.
Please don’t hesitate to share any feedback with us :slight_smile:
