Apple Music Help With Removing Songs
Hey folks, is there anyone here that knows everything when it comes to Apple Music? I have no music on my mac currently and just subscribed to Apple Music subscription. I use to have it ready for requests before. So when i log into it, it shows songs and playlists in Apple Music tab. Im guessing its synced from before somehow. How can i remove all music and playlists from it? Theres not a way in Djay, is there a way through the Itunes side of it?
Figured it out. You have to resync itunes with no music in it then it erases the ones that show in Djay. If you do this, be sure to backup all files from the mac music folder directory on your mac. Then simply put it back after syncing an empty itunes library but keep sync to OFF. Restart your mac and youre good to go!
Hope that helps for some that have that same issue.
Glad to hear you sorted it out @MrG. Thanks for sharing!
