Had yet another syncing issue with Apple. A lot of tracks were greyed out on iPad. Said it was “territory Issue”. Spent 3 hours on phone with Apple tech support. To be fair they were very good. But it got late and we called it a day. This territory issue turned out to be a red herring. Another 3 hours trying to isolate problem on my own again this morning. Figured out the issue was…
Tracks in cloud can be played from Mac Music app, even though not in library. But when syncing when it hits one of these tracks an error occurs and it stops the sync, hence files may have been located initially but as sync was interrupted they are greyed out and can’t be played. I have not tried this on other device.
I think that’s useful to know. But of course, thats not the real issue. The real issue is that we have to use Apple Music to sync in the first place. Its well know how flakey it is. Whenever I have any serious, time wasting issues it’s almost always connected to Apple Music.
Ive posted about this many times. I just would like to know why we have to use Apple Music (please don’t offer workarounds - that’s missing the point completely). It’s all a bit house built on sand. I’ve considered moving from DJay, but, honestly I don’t have the time to start over.
Because of the way IOS is set up you cannot prep and edit files (meta data etc) on IOS you have to do in your computer, so you are forced to use Apple Music.
Why can we not edit metadata, create playlists, add grid info questions points etc (oh and notes I would so love to be able to add notes!) in the DJay Desktop app and sync it from there?
Most salient question: What is the problem? Why is this resisted?
Apple Music creates so much bad feeling, but it’s kind of accepted (and they do have very good support), so DJay gets the bad feeling directed at them by default because they don’t provide for what should be a fundamental thing and so when there are problems, when A LOT of time is wasted, like I said: bad feeling (again and again) and algoriddim cannot help because, well, its: an Apple issue.
Why don’t algorriddim seem to care about syncing? I just don’t get it.
If anyone can suggest another DJ app that does the syncing thing properly - without Apple - that a allows you to edit metatada, create playlists, cue points etc (oh and did I mention notes?) I’d be happy to hear and check it out (even though I’ll just paid another annual fee and would expect to pay much more for another app/subscription).
Thank you
