Device model: MacBook Air M2
Version of operating system: Sonoma 14.4
Version of djay: 5.1.3
Hardware/controllers used: NS4FX
Your question:
hi, i do find the Apple Music playlists I follow in the djay library but I cannot see my own created playlists. why is that? how can I fix that?
Hi @shredder, you’re welcome. Thanks for the clarification. In this case, I recommend that you download the playlists via the Apple Music App on your device first. Then they should appear within the Apple Music Source in djay.
