Device model iPad Pro 12,9 6th Gen.
Version of operating system iOS 18.5
Version of djay 5.3.2
I have a similar problem like ferleis: Only in my case, non of the mentioned tips work. Have already reinstalled 3 times, deleted all data, changed iPad language to English (no improvement) and back to German, countless forced restarts to no avail. Still no editing or deleting.
Hi @Bobob, welcome to the Community! Did you mean to reply to an existing topic or to create a new one? It seems some information is missing here and it’s not clear what you are talking about exactly. Can you please share a link to the original topic or provide some more details to help clarify you issue? Thanks!
I don’t see ANY buttons or icons to edit, rename or manage a playlist and there is no option to delete a track (not even with the three-dot-method). Swiping is not working either.
Hi @Bobob, thanks for the additional info - this is very helpful. I have adjusted the title of this topic accordingly.
Please note that editing the Apple Music Streaming playlists within djay is not currently supported.
You will either need to perform this work via the Apple Music App on your device or you will need to create your playlists within the My Collection Source of djay instead.
I highly recommend that you use My Collection as this source allows you to create playlist that contain songs from multiple sources like Apple Music Streaming, Local Music and other streaming services. I hope that helps!
Also, there is an existing Suggestion topic regarding Apple Music if you would like to cast your Vote in support of this feature over there. I hope that helps!
Hi @pgtaboada, welcome to the Community! Please see above:
If this doesn’t help, please share more details about your setup, plus a short video outlining the issue. Thanks!
Device Model (ex. 2020 iPad Air 4th Gen): Version of operating system (ex. iOS 17.3.1): Version of djay (ex. 5.1.3): Hardware/controllers used (ex. Reloop Ready): Hardware Firmware Version (ex. 2.7):
