I’d be awesome if we could get support for smart playlists on Apple Music. These already work in the Local Music section, so I’m hoping this isn’t too much of a lift from a front end/application side development standpoint. I’m not sure Apple exposes these through their API, although they do sync across devices so there is some non-public API out there that maybe Algoriddim could pull some strings with Apple to get access to.
Thanks for the suggestion! Good idea. I have forwarded this to the dev team for consideration. Thanks!
Hi @gravitybass, I spoke with the engineering team on this one. Unfortunately, there is no public API we can use to access smart playlists, so until Apple add this support on their end we can’t display them in djay.
