Apple Music tracks not loading on Android
Device model: iBasso DX180 128GB
OS: Android 13
DJay Version: 5.2.3
Hardware Controler: None
Whenever I try to load a track from Apple Music (streaming), I get the error: “Could not load track. Error opening file.”
I think it is a file format issue because if I try to load a song that I uploaded in MP3 format, it seems to work fine. But any songs which are purchased or streamed do not seem to load.
FYI, the tracks load and play perfectly in the Apple Music app on the same device
Hi @Pierre_Henry,
Thanks for sharing your report in our forum!
Could you share either a screenshot or screen recording of this issue’s error message so that we can investigate the issue further?
Looking forward to hearing back from you.
Video of error message, as requested
Hi @Pierre_Henry,
Thanks so much for the video, could you please try the following steps below to see if they resolve your issue?
  1. Log out of Apple Music in djay.
  2. Restart your device.
  3. Turn off any VPNs that you may have activated.
  4. Open djay.
  5. Log in to Apple Music via djay.
  6. Play a track.
Additionally, do you have any other Android-based devices you can test this with? It looks like you are using a Digital Audio Player similar to something from Fiio, and I wonder if that is an issue.
I have tried all of those steps and still no luck. I’m not using a VPN. Yes, I am using a DAP - the iBasso DX180 128GB
As I said, the songs play fine in the Apple Music app on the same device - they just will not load in DJay Pro
Hi @Pierre_Henry,
Thank you very much for providing this additional information.
Our engineering team is looking into this issue, and I will share an update with you as soon as one is available.
Thank you for your patience!
Hi @Pierre_Henry,
We wanted to let you know that we are still looking into this Apple Music on Android issue.
It is believed that this is device-specific, and we are still testing this issue thoroughly.
Thanks for your patience and positivity!
Hey team, same here, I can’t play any track linking my Apple Music account. I’m on Android, however it’s working on Iphone
Hi Nathaniel. Any update on this issue?
Hello, I have the same problem, the supposed solution that is said above, I also applied it and with the same result nothing at all, it still doesn’t work. It’s only with Apple Music that doesn’t load the songs, the rest works perfectly, I think it’s a problem that happens in the dapˋs.
My device is Hiby R6 Pro II Android 12 Djay 5.3.1
Any news on this? It’s been over a year and this issue hasn’t been resolved!
Hi @Pierre_Henry, please try installing any available system updates, as that may also fix the underlying issue in the system. Thanks!
I’m on the latest OS version, and the latest version of DJay Pro. Still no luck.
Thanks for confirming @Pierre_Henry
