i just go to open the app and it instantly crashes. Nothing has changed and i used it fine a week ago.
Hi Kyle Powers,
we are very sorry to hear that, can you tell us which macOS, hardware specs and djay version you are using?
Also can you give us some further information about your setup?
Thank you for the follow up. Could you tell us your hardware specifications?
Thank you very much, can send us an exemplary crash log. You can get to them by using the Spotlight search and type in console.
In the opening window you can find a djay pro titled crash log after expanding “User Diagnostic Reports”.
That would help us tons.
Thank you kyle, forwarded your Crash Log to the Devs and will keep you posted.
Hey kyle,
back again.
Could you please delete the RazerAudio.plugin?
It appears that the plugin is causing the crash and there are other applications which are affected as well:
https://discussions.apple.com/thread/5802881?tstart=0
You can find the plugin via:
/Library/Audio/Plug-Ins/HAL/RazerAudio.plugin
Hope this is helping, if after deleting djay Pro is still crashing please let us know asap.
Thank you I am very glad that things are back to normal.
Have fun mixing.
i am using Sierra and the latest version of Djay pro, i just the app store many times to see if i need a update and nothing showed up so its up to date and i uninstalled it and reinstalled it 3 times.
Model Name: MacBook Pro
Model Identifier: MacBookPro8,2
Processor Name: Intel Core i7
Processor Speed: 2.2 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 6 MB
Memory: 4 GB
Boot ROM Version: MBP81.0047.B2C
SMC Version (system): 1.69f4
Serial Number (system): C02H9CHMDV7L
Hardware UUID: 2008AD7E-1AFC-57F9-AF08-391259E4F960
Sudden Motion Sensor:
State: Enabled
Process: djay Pro [8575]
Path: /Applications/djay Pro.app/Contents/MacOS/djay Pro
Identifier: com.algoriddim.djay-pro-mac
Version: 1.3.1 (23639)
App Item ID: 947578651
App External ID: 817224416
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: djay Pro [8575]
User ID: 501
Date/Time: 2016-10-17 17:15:14.691 -0400
OS Version: Mac OS X 10.10.5 (14F1605)
Report Version: 11
Anonymous UUID: EE8C4373-B745-B366-8A92-3A76FC059E74
Time Awake Since Boot: 400 seconds
Crashed Thread: 8 Dispatch queue: com.apple.root.default-qos
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000000000002e
VM Regions Near 0x2e:
__TEXT 000000010a614000-000000010ab56000 [5384K] r-x/rwx SM=COW /Applications/djay Pro.app/Contents/MacOS/djay Pro
Thread 0:: Dispatch queue: com.apple.main-thread
0 com.apple.CoreFoundation 0x00007fff88336fb9 CFSetGetValue + 41
1 com.apple.Foundation 0x00007fff8bab1eaf -[NSObject(NSKeyValueCoding) setValue:forKey:] + 237
2 com.apple.Foundation 0x00007fff8bad49d1 -[NSObject(NSKeyValueCoding) setValue:forKeyPath:] + 339
3 com.apple.Foundation 0x00007fff8bacc1c3 NSKeyValueNotifyObserver + 382
4 com.apple.Foundation 0x00007fff8bacbddf -[NSObject(NSKeyValueObserverRegistration) _addObserver:forProperty:options:context:] + 316
5 com.apple.Foundation 0x00007fff8bacac8a -[NSObject(NSKeyValueObserverRegistration) addObserver:forKeyPath:options:context:] + 107
6 com.algoriddim.djay-pro-mac 0x000000010a6d81d8 0x10a614000 + 803288
7 com.algoriddim.djay-pro-mac 0x000000010a6d916c 0x10a614000 + 807276
8 com.algoriddim.djay-pro-mac 0x000000010a9435ee 0x10a614000 + 3339758
9 com.algoriddim.djay-pro-mac 0x000000010a9438c7 0x10a614000 + 3340487
10 com.algoriddim.djay-pro-mac 0x000000010a9438c7 0x10a614000 + 3340487
11 com.algoriddim.djay-pro-mac 0x000000010a837836 0x10a614000 + 2242614
12 com.apple.CoreFoundation 0x00007fff8842045c __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 12
13 com.apple.CoreFoundation 0x00007fff88310634 _CFXNotificationPost + 3140
14 com.apple.Foundation 0x00007fff8ba91aa1 -[NSNotificationCenter postNotificationName:object:userInfo:] + 66
15 com.algoriddim.djay-pro-mac 0x000000010a6c54af 0x10a614000 + 726191
16 net.hockeyapp.sdk.mac 0x000000010b352f78 __62-[BITCrashManager sendCrashReportWithFilename:xml:attachment:]_block_invoke + 561
17 net.hockeyapp.sdk.mac 0x000000010b34a66e __34-[BITHTTPOperation setCompletion:]_block_invoke_2 + 63
18 libdispatch.dylib 0x00007fff8b2d2700 _dispatch_call_block_and_release + 12
19 libdispatch.dylib 0x00007fff8b2cee73 _dispatch_client_callout + 8
20 libdispatch.dylib 0x00007fff8b2df767 _dispatch_main_queue_callback_4CF + 861
21 com.apple.CoreFoundation 0x00007fff883b73f9 __CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE__ + 9
22 com.apple.CoreFoundation 0x00007fff8837268f __CFRunLoopRun + 2159
23 com.apple.CoreFoundation 0x00007fff88371bd8 CFRunLoopRunSpecific + 296
24 com.apple.HIToolbox 0x00007fff85a6e56f RunCurrentEventLoopInMode + 235
25 com.apple.HIToolbox 0x00007fff85a6e2ea ReceiveNextEventCommon + 431
26 com.apple.HIToolbox 0x00007fff85a6e12b _BlockUntilNextEventMatchingListInModeWithFilter + 71
27 com.apple.AppKit 0x00007fff864828ab _DPSNextEvent + 978
28 com.apple.AppKit 0x00007fff86481e58 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 346
29 com.apple.AppKit 0x00007fff86477af3 -[NSApplication run] + 594
30 com.apple.AppKit 0x00007fff863f4244 NSApplicationMain + 1832
31 libdyld.dylib 0x00007fff8ba895c9 start + 1
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff8ae1c232 kevent64 + 10
1 libdispatch.dylib 0x00007fff8b2d326e _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x00007fff8ae1b94a __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff8af453dd start_wqthread + 13
Thread 3:
0 libsystem_kernel.dylib 0x00007fff8ae164de mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff8ae1564f mach_msg + 55
2 net.hockeyapp.sdk.mac 0x000000010b37b403 exception_server_thread + 202
3 libsystem_pthread.dylib 0x00007fff8af4805a _pthread_body + 131
4 libsystem_pthread.dylib 0x00007fff8af47fd7 _pthread_start + 176
5 libsystem_pthread.dylib 0x00007fff8af453ed thread_start + 13
Thread 4:
Thread 5:
Thread 6:
0 com.apple.HIToolbox 0x00007fff85a3e669 GetCurrentEventLoop + 1
1 com.apple.HIToolbox 0x00007fff85a7685b PullEventsFromWindowServerOnConnection(unsigned int, unsigned char, __CFMachPortBoost*) + 357
2 com.apple.HIToolbox 0x00007fff85a766c3 MessageHandler(__CFMachPort*, void*, long, void*) + 51
3 com.apple.CoreFoundation 0x00007fff88380d87 __CFMachPortPerform + 247
4 com.apple.CoreFoundation 0x00007fff88380c79 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 41
5 com.apple.CoreFoundation 0x00007fff88380beb __CFRunLoopDoSource1 + 475
6 com.apple.CoreFoundation 0x00007fff88372767 __CFRunLoopRun + 2375
7 com.apple.CoreFoundation 0x00007fff88371bd8 CFRunLoopRunSpecific + 296
8 com.apple.AppKit 0x00007fff8654a56b _NSEventThread + 137
9 libsystem_pthread.dylib 0x00007fff8af4805a _pthread_body + 131
10 libsystem_pthread.dylib 0x00007fff8af47fd7 _pthread_start + 176
11 libsystem_pthread.dylib 0x00007fff8af453ed thread_start + 13
Thread 7:: com.apple.NSURLConnectionLoader
2 com.apple.CoreFoundation 0x00007fff88372eb4 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff8837237b __CFRunLoopRun + 1371
4 com.apple.CoreFoundation 0x00007fff88371bd8 CFRunLoopRunSpecific + 296
5 com.apple.CFNetwork 0x00007fff86f81420 +[NSURLConnection(Loader) _resourceLoadLoop:] + 434
6 com.apple.Foundation 0x00007fff8bac8e92 __NSThread__main__ + 1345
7 libsystem_pthread.dylib 0x00007fff8af4805a _pthread_body + 131
8 libsystem_pthread.dylib 0x00007fff8af47fd7 _pthread_start + 176
9 libsystem_pthread.dylib 0x00007fff8af453ed thread_start + 13
Thread 8 Crashed:: Dispatch queue: com.apple.root.default-qos
0 com.razerzone.razeraudio 0x0000000122e3827a HookSetProperty(unsigned int, void*, bool) + 128
1 com.razerzone.razeraudio 0x0000000122e3833d _new_AudioDeviceSetProperty(unsigned int, AudioTimeStamp const*, unsigned int, unsigned char, unsigned int, unsigned int, void const*) + 61
2 com.apple.audio.units.Components 0x0000000127dfe3b0 AUHAL::SetStreamUsage(unsigned int) + 586
3 com.apple.audio.units.Components 0x0000000127dfdcb7 AUHAL::SetupConverter(unsigned int, bool) + 53
4 com.apple.audio.units.Components 0x0000000127df8fb6 AUConverterBase::ChangeStreamFormat(unsigned int, unsigned int, CAStreamBasicDescription const&, CAStreamBasicDescription const&) + 140
5 com.apple.audio.units.Components 0x0000000127df497d AUBase::DispatchSetProperty(unsigned int, unsigned int, unsigned int, void const*, unsigned int) + 1361
6 com.apple.audio.units.Components 0x0000000127df5d00 AUBase::SetConnection(AudioUnitConnection const&) + 124
7 com.apple.audio.units.Components 0x0000000127df449b AUBase::DispatchSetProperty(unsigned int, unsigned int, unsigned int, void const*, unsigned int) + 111
8 com.apple.audio.units.Components 0x0000000127eab393 AUMethodSetProperty(void*, unsigned int, unsigned int, unsigned int, void const*, unsigned int) + 110
9 com.apple.audio.toolbox.AudioToolbox 0x00007fff90ef40ed AudioUnitGraph::ConnectAudioUnit(AudioUnitNodeConnection&, bool) + 325
10 com.apple.audio.toolbox.AudioToolbox 0x00007fff90ef234b AudioUnitGraph::Initialize() + 67
11 com.apple.audio.toolbox.AudioToolbox 0x00007fff90ef22fc AUGraphInitialize + 54
12 com.algoriddim.djay-pro-mac 0x000000010a6e47d1 0x10a614000 + 853969
13 com.algoriddim.djay-pro-mac 0x000000010a7bdab7 0x10a614000 + 1743543
14 libdispatch.dylib 0x00007fff8b2d2700 _dispatch_call_block_and_release + 12
15 libdispatch.dylib 0x00007fff8b2cee73 _dispatch_client_callout + 8
16 libdispatch.dylib 0x00007fff8b2d1dc7 _dispatch_root_queue_drain + 935
17 libdispatch.dylib 0x00007fff8b2d1a1c _dispatch_worker_thread3 + 91
18 libsystem_pthread.dylib 0x00007fff8af47a9d _pthread_wqthread + 729
19 libsystem_pthread.dylib 0x00007fff8af453dd start_wqthread + 13
Thread 9:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff8ae1b3fa __select + 10
1 libsystem_pthread.dylib 0x00007fff8af4805a _pthread_body + 131
2 libsystem_pthread.dylib 0x00007fff8af47fd7 _pthread_start + 176
3 libsystem_pthread.dylib 0x00007fff8af453ed thread_start + 13
Thread 10:: CVDisplayLink
0 libsystem_kernel.dylib 0x00007fff8ae1b136 __psynch_cvwait + 10
1 com.apple.CoreVideo 0x00007fff8b80eff8 CVDisplayLink::waitUntil(unsigned long long) + 240
2 com.apple.CoreVideo 0x00007fff8b80e4b3 CVDisplayLink::runIOThread() + 511
3 com.apple.CoreVideo 0x00007fff8b80e29b startIOThread(void*) + 147
4 libsystem_pthread.dylib 0x00007fff8af4805a _pthread_body + 131
5 libsystem_pthread.dylib 0x00007fff8af47fd7 _pthread_start + 176
6 libsystem_pthread.dylib 0x00007fff8af453ed thread_start + 13
Thread 11:
5 com.apple.Foundation 0x00007fff8bbaec80 -[NSConnection run] + 152
Thread 12:
1 com.apple.Foundation 0x00007fff8badfc31 -[NSCondition waitUntilDate:] + 343
2 com.apple.Foundation 0x00007fff8badfa95 -[NSConditionLock lockWhenCondition:beforeDate:] + 232
3 com.algoriddim.djay-pro-mac 0x000000010a68b874 0x10a614000 + 489588
4 com.apple.Foundation 0x00007fff8bac8e92 __NSThread__main__ + 1345
5 libsystem_pthread.dylib 0x00007fff8af4805a _pthread_body + 131
6 libsystem_pthread.dylib 0x00007fff8af47fd7 _pthread_start + 176
7 libsystem_pthread.dylib 0x00007fff8af453ed thread_start + 13
Thread 13:
Thread 14:
Thread 15:
Thread 8 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000000 rcx: 0x0000000000000001 rdx: 0x0000000000000000
rdi: 0x00006000002354a0 rsi: 0x000000000000000a rbp: 0x000000010f1d9970 rsp: 0x000000010f1d9960
r8: 0x0000000000000000 r9: 0x0000000000000010 r10: 0xfffffffffffffb34 r11: 0x0000000000000590
r12: 0x0000000000000000 r13: 0x0000000000000000 r14: 0x0000600000013280 r15: 0x0000000000000000
rip: 0x0000000122e3827a rfl: 0x0000000000010202 cr2: 0x000000000000002e
Logical CPU: 0
Error Code: 0x00000006
Trap Number: 14
Binary Images:
0x10a614000 - 0x10ab55fff +com.algoriddim.djay-pro-mac (1.3.1 - 23639) /Applications/djay Pro.app/Contents/MacOS/djay Pro
0x10aca6000 - 0x10ad03fff +com.algoriddim.ARGLKit (1.0 - 1) /Applications/djay Pro.app/Contents/Frameworks/ARGLKit.framework/Versions/A/ARGLKit
0x10ad56000 - 0x10ad5dff7 +com.algoriddim.ARUtilities (1.0 - 1) /Applications/djay Pro.app/Contents/Frameworks/ARUtilities.framework/Versions/A/ARUtilities
0x10ad68000 - 0x10ae4cff7 +com.algoriddim.ARGLVisualsKit (1.0 - 1) /Applications/djay Pro.app/Contents/Frameworks/ARGLVisualsKit.framework/Versions/A/ARGLVisualsKit
0x10aec4000 - 0x10aef3ff7 com.apple.iTunesLibrary (12.3.3 - 12.3.3.17) /Library/Frameworks/iTunesLibrary.framework/Versions/A/iTunesLibrary
0x10af12000 - 0x10af72ff3 +algoriddim.com.ARGLVideoProcessingKit (1.0 - 1) /Applications/djay Pro.app/Contents/Frameworks/ARGLVideoProcessingKit.framework/Versions/A/ARGLVideoProcessingKit
0x10afa0000 - 0x10b044ff7 +org.xiph.vorbis (1.2.3 - 1.2.3) /Applications/djay Pro.app/Contents/Frameworks/Vorbis.framework/Versions/A/Vorbis
0x10b07e000 - 0x10b2befef +com.spotify.Core (1.0 - 1) /Applications/djay Pro.app/Contents/Frameworks/libspotify.framework/Versions/12.1.178/libspotify
0x10b32a000 - 0x10b336fff com.apple.StoreKit (1.0 - 376.29) /System/Library/Frameworks/StoreKit.framework/Versions/A/StoreKit
0x10b349000 - 0x10b3abff7 +net.hockeyapp.sdk.mac (3.1.0 - 28) /Applications/djay Pro.app/Contents/Frameworks/HockeySDK.framework/Versions/A/HockeySDK
0x10b40b000 - 0x10b435fff +com.paddle.PaddleMAS (1.1.6 - 118) /Applications/djay Pro.app/Contents/Frameworks/Paddle-MAS.framework/Versions/A/Paddle-MAS
0x10b456000 - 0x10b48dfff com.apple.audio.midi.CoreMIDI (1.10 - 88) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x10b4bb000 - 0x10b4beff7 +org.xiph.ogg (1.1.4 - 1.1.4) /Applications/djay Pro.app/Contents/Frameworks/Ogg.framework/Versions/A/Ogg
0x10b4c8000 - 0x10b4efff7 com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x10b50e000 - 0x10b51cfff +net.liquidx.EyeTunes (1.3.4) /Applications/djay Pro.app/Contents/Frameworks/EyeTunes.framework/Versions/A/EyeTunes
0x10b52f000 - 0x10b537ff7 +algoriddim.com.ARMovieKit (1.0 - 1) /Applications/djay Pro.app/Contents/Frameworks/ARMovieKit.framework/Versions/A/ARMovieKit
0x10b549000 - 0x10b6d6ff7 +com.algoriddim.MediaLibraryOSX (1.0 - 1) /Applications/djay Pro.app/Contents/Frameworks/MediaLibraryOSX.framework/Versions/A/MediaLibraryOSX
0x10b980000 - 0x10b988fff com.apple.SyncedDefaults (2.0 - 212.3) /System/Library/PrivateFrameworks/SyncedDefaults.framework/SyncedDefaults
0x10ff68000 - 0x10ff83ff3 com.apple.security.csparser (3.0 - 57031.40.8) /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
0x110001000 - 0x11000efff libGPUSupport.dylib (11.1.6) /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
0x1103dd000 - 0x1103ddfef +cl_kernels (???) cl_kernels
0x1103eb000 - 0x1103ebff5 +cl_kernels (???) cl_kernels
0x1108d1000 - 0x1109b7fef unorm8_bgra.dylib (2.4.5) /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x112cc1000 - 0x11302ffff com.apple.driver.AppleIntelHD3000GraphicsGLDriver (10.0.35 - 10.0.0) /System/Library/Extensions/AppleIntelHD3000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD3000GraphicsGLDriver
0x113142000 - 0x1133dcfff com.apple.AMDRadeonX3000GLDriver (1.32.25 - 1.3.2) /System/Library/Extensions/AMDRadeonX3000GLDriver.bundle/Contents/MacOS/AMDRadeonX3000GLDriver
0x11ffc3000 - 0x11ffc7fff com.apple.audio.AppleHDAHALPlugIn (272.18.3 - 272.18.3) /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x1225e0000 - 0x122604ff7 +com.lexicon.io.hal (2.1.8) /Library/Audio/Plug-Ins/HAL/Lexicon IO Desktop Series.HAL.plugin/Contents/MacOS/Lexicon IO Desktop Series.HAL
0x122e33000 - 0x12322efff +com.razerzone.razeraudio (1.0.0 - 1.0) /Library/Audio/Plug-Ins/HAL/RazerAudio.plugin/Contents/MacOS/RazerAudio
0x127df0000 - 0x12800dff3 com.apple.audio.units.Components (1.12 - 1.12) /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x7fff6d48b000 - 0x7fff6d4c1887 dyld (353.2.3) /usr/lib/dyld
0x7fff81702000 - 0x7fff81a35ff7 libmecabra.dylib (666.7) /usr/lib/libmecabra.dylib
0x7fff81a8c000 - 0x7fff81abcff3 com.apple.CoreAVCHD (5.7.5 - 5750.4.1) /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff81ba3000 - 0x7fff81bbffff com.apple.GenerationalStorage (2.0 - 209.11) /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff81bc0000 - 0x7fff81ff0fff com.apple.vision.FaceCore (3.1.6 - 3.1.6) /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff81ff1000 - 0x7fff82100ff3 com.apple.desktopservices (1.9.3 - 1.9.3) /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff82101000 - 0x7fff8217ffff com.apple.CoreServices.OSServices (640.4 - 640.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff821b7000 - 0x7fff821c2fff libGL.dylib (11.1.6) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff82206000 - 0x7fff82470ff7 com.apple.imageKit (2.6.1 - 850) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff82778000 - 0x7fff82a5fffb com.apple.CoreServices.CarbonCore (1108.6 - 1108.6) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff82adf000 - 0x7fff82b4efff com.apple.SearchKit (1.4.0 - 1.4.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff82b4f000 - 0x7fff82b5aff7 com.apple.DirectoryService.Framework (10.10 - 187) /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff82b5b000 - 0x7fff82b60ff7 com.apple.MediaAccessibility (1.0 - 61) /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff82b61000 - 0x7fff82b6afff libGFXShared.dylib (11.1.6) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff82b6b000 - 0x7fff82cf9fff libBLAS.dylib (1128) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff82cfa000 - 0x7fff82cfbfff libDiagnosticMessagesClient.dylib (100) /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff82cfc000 - 0x7fff82d0aff7 com.apple.opengl (11.1.6 - 11.1.6) /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff82d0b000 - 0x7fff82d51ff7 libFontRegistry.dylib (134.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff82d70000 - 0x7fff82d74fff com.apple.TCC (1.0 - 1) /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff82d75000 - 0x7fff82d77ff7 libsystem_coreservices.dylib (9) /usr/lib/system/libsystem_coreservices.dylib
0x7fff82d78000 - 0x7fff82d87fff com.apple.LangAnalysis (1.7.0 - 1.7.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff82d88000 - 0x7fff82da3ff7 com.apple.aps.framework (4.0 - 4.0) /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff82da4000 - 0x7fff82dbdff3 com.apple.openscripting (1.6.4 - 162.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff82dbe000 - 0x7fff82f6dfff GLEngine (11.1.6) /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff82f6e000 - 0x7fff8309efff com.apple.UIFoundation (1.0 - 1) /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff830c4000 - 0x7fff830c7fff com.apple.help (1.3.3 - 46) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff830c8000 - 0x7fff833caffb com.apple.GeoServices (1.0 - 1077.0.18) /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff834eb000 - 0x7fff8350fff7 com.apple.Sharing (328.17 - 328.17) /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff83518000 - 0x7fff83532ff7 libextension.dylib (55.2) /usr/lib/libextension.dylib
0x7fff83df9000 - 0x7fff83dfdfff libCoreVMClient.dylib (79.1) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff83dfe000 - 0x7fff83ed4ff3 com.apple.DiskImagesFramework (10.10.5 - 398) /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff83f32000 - 0x7fff83f32fff com.apple.CoreServices (62 - 62) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff83f33000 - 0x7fff83f37fff com.apple.IOAccelerator (156.16 - 156.16) /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff83f3b000 - 0x7fff83f6cff7 com.apple.ProtectedCloudStorage (1.0 - 1) /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff83f7a000 - 0x7fff83f7efff com.apple.CommonPanels (1.2.6 - 96) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff8421d000 - 0x7fff84229ff7 com.apple.OpenDirectory (10.10 - 187) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff842fb000 - 0x7fff842fdfff libquarantine.dylib (76.20.1) /usr/lib/system/libquarantine.dylib
0x7fff842fe000 - 0x7fff84387ff7 com.apple.CoreSymbolication (3.1 - 57020.2) /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff84388000 - 0x7fff84389fff liblangid.dylib (117) /usr/lib/liblangid.dylib
0x7fff8438a000 - 0x7fff8439bfff libcmph.dylib (1) /usr/lib/libcmph.dylib
0x7fff8439c000 - 0x7fff8439cfff com.apple.ApplicationServices (48 - 48) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff8439d000 - 0x7fff8439fff7 libutil.dylib (38) /usr/lib/libutil.dylib
0x7fff843d9000 - 0x7fff843fafff com.apple.framework.Apple80211 (10.3 - 1030.71.6) /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff8445b000 - 0x7fff844a8ff7 com.apple.print.framework.PrintCore (10.3 - 451.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff844a9000 - 0x7fff844f8ff7 libstdc++.6.dylib (104.1) /usr/lib/libstdc++.6.dylib
0x7fff844f9000 - 0x7fff84777fff com.apple.RawCamera.bundle (6.05 - 806) /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff8478d000 - 0x7fff847bcfff com.apple.securityinterface (10.0 - 55058) /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff847bd000 - 0x7fff8484eff7 libCoreStorage.dylib (471.30.1) /usr/lib/libCoreStorage.dylib
0x7fff84862000 - 0x7fff84986ff7 com.apple.LaunchServices (644.56 - 644.56) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff84989000 - 0x7fff84991ff7 com.apple.icloud.FindMyDevice (1.0 - 1) /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
0x7fff84992000 - 0x7fff84998fff libsystem_trace.dylib (72.20.1) /usr/lib/system/libsystem_trace.dylib
0x7fff84999000 - 0x7fff849e7ff7 com.apple.ImageCaptureCore (6.3 - 6.3) /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff849ea000 - 0x7fff849f1fff com.apple.NetFS (6.0 - 4.0) /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff849f2000 - 0x7fff84b36ff7 com.apple.QTKit (7.7.3 - 2890.9) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff84b37000 - 0x7fff84b92ff7 libTIFF.dylib (1241) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff84b93000 - 0x7fff84bc3ff3 com.apple.GSS (4.0 - 2.0) /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff84bc4000 - 0x7fff84bcbfff com.apple.network.statistics.framework (1.2 - 1) /System/Library/PrivateFrameworks/NetworkStatistics.framework/Versions/A/NetworkStatistics
0x7fff84cae000 - 0x7fff84cc8ff7 com.apple.Kerberos (3.0 - 1) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff84cd6000 - 0x7fff84ebbff7 libicucore.A.dylib (531.50) /usr/lib/libicucore.A.dylib
0x7fff84ebc000 - 0x7fff84ec7fff libcommonCrypto.dylib (60061.30.1) /usr/lib/system/libcommonCrypto.dylib
0x7fff84ec8000 - 0x7fff84ffaff7 com.apple.MediaControlSender (2.0 - 215.18) /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender
0x7fff85105000 - 0x7fff85171ff3 com.apple.MMCS (1.3 - 327.5) /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
0x7fff85188000 - 0x7fff8518cff7 libGIF.dylib (1241) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff851e5000 - 0x7fff8520dfff libxpc.dylib (559.40.1) /usr/lib/system/libxpc.dylib
0x7fff8520e000 - 0x7fff85216fe7 libcldcpuengine.dylib (2.4.5) /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff85217000 - 0x7fff85237ff7 com.apple.MultitouchSupport.framework (264.6 - 264.6) /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff85238000 - 0x7fff852ceff7 com.apple.cloudkit.CloudKit (283.67.4 - 283.67.4) /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff852cf000 - 0x7fff852e9ff3 com.apple.Ubiquity (1.3 - 313) /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x7fff852ea000 - 0x7fff85401fe7 libvDSP.dylib (516) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff857b3000 - 0x7fff85812fff com.apple.AE (681.5 - 681.7) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff85813000 - 0x7fff8581dff7 com.apple.NetAuth (5.2 - 5.2) /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff8581e000 - 0x7fff8584afff libsandbox.1.dylib (358.20.5) /usr/lib/libsandbox.1.dylib
0x7fff8584b000 - 0x7fff858b9ff3 com.apple.Heimdal (4.0 - 2.0) /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff8595c000 - 0x7fff859a6fff com.apple.HIServices (1.22 - 523) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff859a7000 - 0x7fff859cdfff com.apple.ChunkingLibrary (2.1 - 163.6) /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff859ce000 - 0x7fff859d0fff com.apple.CoreDuetDebugLogging (1.0 - 1) /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framewo
It is really the greatest feeling to finally see a application open up, especially when you haven’t seen it in like 2 weeks. Thank you so much man. This service was really great, you guys got back really fast. Which keeps me loyal. Once again thanks man.
