Applied Logic to Effects Panel
A minor, but simple improvement would be to list the effects in a logical sequence. An example would be Echo, so it reads Echo 1/2, Echo Out 1/2, Echo Out 3/4, Echo Out 1. And have them all on the same block of 4
Currently there is no logic applied. Whilst you can sequence them 1 by 1 so you achieve this order, the software could do it too.
Hi @David_Bielby, are you referring to the selection list shown below?
Are you aware that you can create a favorites/star list and have these organized in your order of preference?
I thought i had replied. My reply was simple. I was not aware of the favourites but that is not really the point. My suggestion was basic logic. When you have an effect that has 1/2, 3/4, 1, just put them together . Dont put 1 at the top of a list and 1/2, 3/4 at the bottom of the list.
Pretty sure this improvement could be done in about 1 hour
Thanks for the follow up and additional info @David_Bielby. I will pass this onto the dev team for consideration. Thanks again!
