Apologize if this is a dumb question. If I am using Automix and set start/stop points for specific songs (using Tidal), are those only stored locally to my device? For example, if I was working through a playlist on my Mac, would they also be present on my iPad?
@milquetoast if you have iCloud Sync enabled on both devices in the djay settings they should be automatically carried across. Alternatively you can manually copy the djaymedialibrary database between devices.
