Hi, I have both djay 2 and djay pro installed on my ipad. I was wondering if anyone knew if I buy the FX pack for one do I get it free for the other, or will that be a separate purchase?
I have the FX pack for Djay 2.
It seems to be active in Pro aswell.
But i also have bought the pack for Pro in the macbook, so i don’t know wich one activates it on Pro for Ipad.
Hello,
I have the same question, and as you, have both Djay 2 and Djay Pro installed on my iPad 3. The advice I got from Algoriddim support was this:
In order to restore your FX Pack, please do the following:
At the device you purchased the FX Pack with, please enable “iCloud Drive” for djay 2 / djay Pro. Make sure you’re using the Apple ID you purchased the FX Pack with. Also, please tap on “Restore” here.
Now, switch on “iCloud Drive” for djay 2 / djay Pro on your other device(s), too. Just make sure you’re logged in with the same Apple ID.
Fully restart djay and try it again
What I have done?
- I have clicked Restore purchases in Djay 2.
- I restarted Djay pro and Djay 2
- No FX package shows up in Djay Pro
It could be that we have both apps on the same iPad that causes the issue. I have emailed support and am awaiting a reply.
Best regards,
Hi Roy and Lucas,
Tried several times, but never got it to work. Guess it could be an iOS/iCloud-issue.
So I decided to purchase again in Djay Pro for iPad. It is cheap and now I got going with all FX.
Hi Roy,
Once you purchased the FX-Pack, you can use it in djay 2, djay Pro iOS and djay Pro MacOS.
Best Regards,
Lukas
