More and more Vinyl artwork on label (aka picture discs) are not loading and showing as expected.
If you reload the song, then the artwork is back on the disc.
The song upper icon (on the upper part of the display), is never blank. Always displaying the right artwork.
Artwork is displaying correctly when searching into playlists.
All my library artwork is embedded, and AAC 128k format. No Mp3.
Another bug happens when you search a dong with the keyboard. When you type a word, the sound is briefly cut.
Setup: DJAY version5.2.9- iPad 9th generation, iPad OS 18.3.1. BUDDY (RELOOP) controller.
Hi @arlandajim, thanks for the details about your setup and the issue - this is very helpful! I was unable to replicate this as you’ve described. Can you please share some screenshots or capture a short video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
This is very helpful. Thanks @arlandajim. I am still not able to replicate, but I have passed this onto our engineering team for further review.
In the meantime, please close djay and follow the procedure linked below to perform a Forced Restart of your iPad: Force restart iPad - Apple Support. After restarting, please retest and let me know if the issue persists. Thanks!
Hi there.
I did the force restart. And even re-analyze the entire iPad djay library.
It makes no difference.
Next step is to erase all library on iPad and re-transfert from the Mac from scratch.
But I won’t do it before you had replied.
Best regards
Okay, thanks for checking @arlandajim. We’ll have to wait until next week when the engineering team can check and try to reproduce. I’ll report back when I have news. Thanks!
