Hey, I have a Pioneer DDJ-WeGo, the first one (WeGo 1) it works great and everything is all good.
The problem is that there are 3 pre-assigned effects to the “FX1 FX2 and FX3” buttons. I was wondering how I can change the assigned effects to effects I have purchased from from you or just re-arrange them so I know which effect each button triggers.
I would much prefer this instead of having to manually go to the “sliders area, where the effects, cue points etc. are located”
Much appreciated!
Besides this everything is top notch and I’m loving DJAY!!! Keep it up
