Can anyone please advise how to assign pads to FX on Denon Prime 4+ controller?
@Paul_Collins1 this will need to be done by editing the built-in MIDI mapping for the Denon Prime 4+. I recommend you select a pad mode that you are not using and map each button to Instant FX 1-8 instead.
Please refer to the attached FAQs for MIDI Mapping on iOS and macOS.
