Assistance!!!!
I have djay app and Spotify Premium, but for some reason Djay is not recognizing that I have spotify premium.
Support will be back in two months to help you… in the mean time, they will tell you to be patient as you dj in front of hundreds of people.
The advice we get from Algoriddim in this case is this:
go to “www.spotify.com”;
log in with your Spotify account
scroll down till “log out everywhere”
re-open your djay app and try it again!
Good luck!
Hi guys,
thank you Emmanuel for your post and DJ Boum Boum for your help!
Yes please try DJ Boum Boum’s precise advice, thanks for that.
If it is still not working, please don’t hesitate to contact us right away via support@algoriddim.com.
Keep it up,
Hi Emmanuel Enime,
thank you for your reply and your patience.
Could you please contact our support via support@algoriddim.com and send a screenshot of the pop-up window where you can only proceed by canceling. That would help us tons in order to reproduce your issue.
Thank you very much Emmanuel and you other guys for trying to help.
:frowning: This did not work for me!! I really don’t know where to go from here?
I will explain what is happening: I open up djay Pro app, I click the link that says Login to Spotify, a pop up window appears and I am able to log in, once I am logged in I can see my account, the only way I can get away from this pop-up window is if I press cancel which then sends me to a prompt screen saying “Spotify Premium required…get it or no thanks”.
Help??!?
Lol, it is working now, I think it was just a matter of me scrolling down on that pop-up window. I did not realize that scrolling was an option. Sorry for being a bother, also appreciate your willingness to assist!!
Best regards
Hahahaha, this is actually very funny!! I do appreciate your sense of humor :slight_smile:
