Hello, it looks like djay Pro 2 can’t see mu Audio 2 dj native instrument interface. Is that possible? Thanks
Max
Hello thanks for your message, I’m on OS for MacBook, not iOS. Is it ok as well?
Max
Hello, thanks.
Well I cannot see it, I plug audio 2 dj it and then as you can see from the pic it is not showing as an alternative output
Hi Max,
the Audio 2 DJ is supported by djay for iOS. Can you send us an exemplary video via support@algoriddim.com to show us your setup?
Cheers,Lukas E.
Hi Max,
sorry for the misunderstanding. Yes it is supported with djay Pro 2 for Mac too.
