Hey everyone,
got a problem with my Denon MC 4000. The audio output on my headphones is not in synch with my master audio. I’d say the master is about a half a second to a second delayed.
Is there a setting in Djay to delay the headphone output or is there a trick with the Denon?
@Fresh27 is your master audio device a Bluetooth speaker? Even if you are hardwired to a BT speaker there can be a delay. Sometimes this can be solved by turning Bluetooth OFF on your source iOS device. Unfortunately, with some BT speakers this doesn’t help. If possible, try testing with a non BT speaker to see if you still have the delay issue.
