Headphone mini-jack’s are not meant to be used for connecting your controller to a PA system. If you do however, how 're you going to use your headphone for pre-cueing and mix/match?
Meanwhile, I’m pretty frustrated and disappointed that Algoriddim seems to keep on pushing for adding new gimmicks, instead of fixing real world problems like this one. They still seem to target at kids and bedroom-dj’s, instead of pro’s.
Hello Jack sure the mini Jack wasn’t meant for that but I’m just trying to understand where the problem comes from and give as much details as I can to the Algorithm Djay team to solve the problem.
Actually I had a gig last time and the micro jack didn’t bring any improvement I had 3 audio dropout on songs loading … So same problem.
The weird thing is at home I had no issue at all connecter to the micro jack …
I also ended my Djay Pro Ai subscription to test and the problem is exactly the same …
I’ve had the same issue over 1 year across both the iPad Air and the iPad Pro. When selecting a new track the sound cuts out and controller freezes. The app carries on playing, be it without sound coming out. This makes it impossible to use this set up for a gig. Very disappointed.
I’ve reported this before and followed all the usual guidance, changed cables, ensure I only use the apple connectors, and started the app up in the very specific way, nothing fixes this. When will this basic be fixed?
Any updates on this issue, had my DDJ400 for 3 days not managed to use it for more than 20 mins without this issue occurring. It’s boxed up and ready to go back now.
Pioneer is asking for anyone experiencing this issue to file an inquiry ticket so their support teams can gather additional information and provide 1:1 support.
Any news on the dropouts? Was dropping out regularly on my iPhone 7 with iOS 14, I just assumed it’s the port as it needs a wiggle to charge it sometimes…
I have a iPad mini 3 that’s on iOS 12 but I can’t hear no sound on the pre cue, any help?
I have the latest ipad air,
Running the latest firmware on the ipad to date.
I use the £65 apple official usb c adaptor for the ddj400 to be connected along side power for the ipad.
Latest djay software.
Even updated the firmware on my ddj400 using a laptop.
And about 20-40 mins into playing tracks, at random when i select my next track to load using the ddj400 and not on the ipad, the audio cuts out.
But when looking at the ddj400, the levels are showing and it is still connected to the ipads software (djay) when i move the tempo, eq, crossfader etc it still shows manipulation on the app, and the track is still playing on both the app and the ddj400, just the audio stops coming through the speakers.
Get it fixed, i have been dealing with this problem for months, this is all expensive equipment when you total it all up, it should be able to do something as simple as play audio with no crashes.
I ordered a cable the directly connects my ddj 400 straight to my ipad air. (Usb b to c)
To see if this would resolve the issue rather than using the apple usb c multi media port adapter.
Plus the Djay app also had an update today with new features and “bug fixes”
And after 25 minutes into my set, again the audio drops out when selecting my next track.
My ipad air 2020 model was on 95% charge, connected straight to the ddj 400 directly,
Latest software of IOS and latest update of the Djay app.
I literally cannot think of any other solution now, that was my only way of thinking that might be causing the drop out, the adapter. But it seems thats not the case, it has to be the Djay software.
The image attached is the exact cable i purchased.
Have the same problem with the same setup. DDJ 400 with iPad Pro 2020 in Djay.
After random times there is no sound out of my Speakers if I’m fading to the next track. And sometimes there is a problem with pre cuing with my headphones as well. No sound.
Always had to restart the app and reconnect the DDJ 400.
Today Algoriddim released a new update in the App Store , does anyone knows about any fixes? Maybe it is fixed now?!
Unfortunately, the update has not fixed it. Same problem occurs. And i also have the same problem with the headphones along with the audio in general cutting out.
Yes indeed, as @_gUrU pointed out, we’re happy to share that this issue should be fixed now with the release of djay Pro AI for iOS version 3.6.6. Please update your app when you get a chance.
Thanks again for bringing this to our attention. Of note was the fact that this issue only seemed to affect certain USB adapters, which made the issue more difficult to track down.
Looking forward to your feedback here. Thanks again for your patience while our team investigated the issue!
