Audio drops out when scrolling
Using Pioneer S11 when scrolling playlists using the browse wheel if you turn it fast you get audio dropouts. Does not happen when scrolling using MacBook track pad.
Hi @DJWillby,
Thanks for sharing this report!
May I ask what version of djay you are using when encountering this issue?
I have this problem too.
MacBook Pro Retina 13-inch 2015, macOS 10.14.6, Intel core i7, 3.1 GHz, 16 Gb RAM, Inel Iris 6100, 2 TB NVMe SSD, newest version of djay Pro AI.
DJM-S11
Reloop Elite
DJM-S9
Turntables with DVS
Just tried wirh the latest update and still the same issue
