I’m experiencing a rather unique problem. Certain audio elements in a handful of songs disappear when using Djay Pro with Split Output engaged on iPad Pro. This is while simply playing the track, and happens in both the headphones and speakers. While sometimes it is unnoticeable, sometimes it’s entire melodies. It’s almost as if they are lost in the mix somehow, however the missing elements aren’t necessarily sounds dedicated to the right or left channel.
This problem happens both with the Geffin cable, and my Numark Mixdeck Quad, with mono audio disabled in the settings, and only when Split Output is turned on.
