If I assign an FX slot to a specific stem, the audio effect cuts off as soon as the track stops playing. This is most obvious if you are trying to apply an echo to vocals when using a cue point to trigger.
Hi @Rob_Grimes, this is a known limitation of the current Neural Mix engine. The engineering team is aware of this, but it’s currently a processing power limitation.
