I have a lag between the cue output and the main output, is there a setting I need to change?
Hi Steven,
What are you using as main output? How are your devices connected to the iPad?
I’m having exactly the same problem, cueing with headphones and main output into usb in Onkyo amp.
Do you think there will be a resolution to this?
I have it connected to an idj pro and an onkyo amp
