Audio latency, and screen frame late has dropped? only USB
  • Device model (Sony Xperia1Ⅵ):
  • Version of operating system (Android 15):
  • Version of djay (5.2.9):
  • Hardware/controllers used (DDJ-FLX4):
Your question:
Hi, there.
I play DjayPro on Android with DDJ-FLX4 and FLX2.
But, It has latency.
So,the timing of pushing hot cues is out of sync with the sound and waveform
There is latency when connecting via USB.
There is no latency when connected via Bluetooth and only use Djay on phone device.
And, connected via USB, the phone screen also becomes choppy, as if the frame rate has dropped…?
Using Rekordbox, neither introduces any latency.
I’ve tested it with various USB cables, but there is some latency.
Do I need to do any settings in the djay app?
Thank you.
Hi @RYA0422, sorry to hear you’re experiencing this issue. Thanks for the details about your setup and the issue. To help us troubleshoot this further, can you please try to capture a short video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Such a delaye.
I used a sampler to make it easier to understand.
Thanks for the video @RYA0422. This is very helpful. I just checked with our official support team and they informed me that they are already working with you directly via email. So, I’m going to let them take things from here and consider this topic closed. Thanks!
Okay, thank you.
I hope this solves the problem.
You’re welcome @RYA0422
