Audio looper packs
I downloaded all the audio looper packs provided with djay app on my iPhone but I need to create my own customized
Audio pack, can this be done using the record function?
Hi Bassem,
at the moment creating your own audio looper pack is not supported.
I will push the topic internally.
Thank you for your feedback.
Cheers,Lukas
Ok thank you Lukas
