Hi @all,
have a little problem, but let me first describe my setup.
i am using a denon 4500hc as midi play and a external mixer in addition.
Could manage to map midi player without any problems, but i can not handle the audio output. both outputs are lead into one output channel so that mixing and pre listening is not possible.
Can you please describe how i can split the audio output so that pre listening and mixing is possible?
Thanks a lot guys
Greetings from Germany
