Audio recording
Is there a way to manage my audio recording I made on DJ app for iPhone? I can load the tracks individually but is there a way I can put them in a playlist under my collection?
Hi @Bassem,
Thanks for posting to the community!
Yes, You are able to access your recordings and put them into playlists in your My Collections source.
  1. Head to the Files Music Library.
  2. Tap the plus button in the left hand corner.
  3. Tap “Add Files”.
  4. In the Files app pop-up head to the folder labeled djay.
  5. Choose the audio recording you wish to add to your playlist(s).
  6. Go to the Linked Files tab under the Files source in djay.
  7. Tap the 3 dots next to the recording you would like to add to your playlist(s) in My Collections.
  8. All done!
We look forward to seeing you in the community again!
Thank you Nathaniel, it worked very well :+1::smiley:
