Audiobus and inter app audio problems
Hi
Anyone out there can you advise or help
Tried using inter app audio and audiobus on beatmaker 2 and auria
But when you load up your song It does not play.
I can see load up the song I selected but when u hit play it does not play the song
Why???
Hi Marcus,
Which app version are you using? To determine djay’s version number, tap the gear button and scroll down to the bottom.
Glad to hear that!
Thank you
It seems to work as I have got the latest update yesterday
Sounds cuts out a bit when doing a 2 finger cross fade scratch when using inter app audio
But seems fine if you do it via audiobus
Loyal fan since the first day djay released
Got vjay now djay 2 ohhhh yeahhhh
