Auto (hi-pass/lo-pass) filter slides back to default state on every manipulation for one track. It occurred when I used a hardware controller (reloop beatpad) with an iPad mini retina. The auto filter would slide back anytime I tried to edit the value, even if my knob was far more to the right, which gave a lot of funky side-effects. Because my knob was at about 75% for example but the actual software filter was still in the middle. When I would manipulate just a little bit, it would jump to 75% and automatically slide back. In addition, it didn’t even matter if I did with the controller or inside the app itself. If I slided the slider in-app it would totally trip and slide back to the middle. However, this was only for one of the two tracks. The other side worked perfectly. Only a hard reset of the app fixed it.
I figured I could use this app in a professional way, however I keep stumbling across bugs which keep me from mixing a set. All these bugs are not only critical but also blockers for me. What does the release cycle look like?
