Auto Gain issue with Numark NS7III
*NOTE: the gain goes all out on the new song when the mix starts
Hi @Thierry34, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Also, can you please try to capture a short video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Hello, I use a mini mac M2 macos sequoia 15.1.1
Thanks for the additional info @Thierry34.
  1. What version of djay are you using?
  2. Are you running the latest Numark NS7III firmware? Please share the version number.
  3. Can you please explain in more detail what exactly is happening? A short video as suggested above would really help me to troubleshoot this with you further.
djay pro version 5.2.6
Thanks. Please first try updating the recently released djay 5.2.6 to see if that solves your issue. If not, please share more details or a short video. Thanks again!
the winnings move on their own, I don’t touch anything, deck 1 always goes all out
I use the controller as a sound card with only the master gain and I run djay pro.
it’s like that all the time. Not just on automix
@Thierry34 are you talking about “Automix” or “Auto Gain”?
Also, I don’t know what you mean by “winnings”:
the gain. ,désole je suis français
the gain goes all out. I don’t receive anything, he does it alone. only platine 1
@Thierry34 please try navigating to the djay Settings>Sound and turn Auto Gain OFF.
it’s done, nothing changes. I looked in the settings and found nothing
Also make sure that Save and Restore Manually Set Gain Values below that is turned OFF.
yes it is disabled …
Does the same problem happen when the NS7 is not connected to your Mac?
@Thierry34 I feel like I still don’t fully understand the problem you are experiencing here. Please record and share a short video so that I can fully see what you are trying to describe. This will make things a lot easier. Thanks!
