Auto-Repeat feature really needs separate on/off option between video and audio!
Hi, with my performance, vjay for iPad is a must now. Thank you so much for developing such amazing app, but one thing it really irritates me…
pls check my performance: http://youtu.be/t1ZYe5QBtJ0
When I change audio and video to next song, I often forgot the auto is also repeated. This is because real turntable never auto-repeats. What happens is previous song is played unwillingly again. Video repeat is totally fine, since no graphic is rather miserable. and I can later change it which is cool.
Please please please consider to add a feature like, video/audio separate auto-repeat!
Warmest regards,
Thanks for posting your request!
By the way, if “Auto-Repeat” is turned OFF and the audio track is longer than the selected video, then the video will still repeat automatically.
So, in your case, it sounds like all you need to do is turn off “Auto-Repeat”.
