Automatic Track Metadata Repair Using AI and DSP Databases
YOUR SUGGESTION:
I would like to request an AI based feature that automatically enriches and repairs metadata in a local DJ library by referencing major streaming music platforms.
Problem
Many DJ files contain incomplete or incorrect metadata, especially release year. This is common with edits, remixes, transitions, intro versions, and DJ tools. The software often sorts by the main BPM or incomplete tags, which makes high quality tracks easy to miss during live sets.
Manually fixing metadata across large libraries is time consuming and inefficient. i do get very busy with this task tho but had an idea to implement into the software.
Proposed solution
Introduce an AI metadata engine that scans a user’s library and automatically updates missing or incorrect fields using trusted streaming platform databases.
Data sources
Apple Music
Spotify
TIDAL
These platforms already maintain highly accurate release year and artist metadata.
Core functionality
• Scan local library for missing or inconsistent metadata
• Detect artist name and track title using existing tags and file names
• Cross reference matches against streaming platform databases
• Automatically populate release year in the user’s library
• Preserve original local metadata unless the user approves changes
Remix and edit handling
For remixes, edits, intros, transitions, and DJ versions that do not exist exactly in streaming databases:
• Use artist name and base track title to find the closest official release
• Suggest a match instead of forcing an overwrite
• Allow user approval per track or batch approval
• Display confidence score for each match
Example:
“Artist – Track Name (DJ Edit)” → matched to “Artist – Track Name (Original Release Year)”
User controls
• Toggle AI metadata sync on or off
• Select which fields can be updated such as year only
• Manual approve, batch approve, or auto apply above a confidence threshold
• Full undo history
Benefits
• Accurate release year sorting
• Cleaner, more reliable libraries
• Faster prep time
• Less manual metadata editing
• Better live performance track discovery
This feature would dramatically improve library management for professional DJs and bring DJ software closer to the intelligence level of modern music platforms while keeping full user control.
Thanks for the suggestion! I’ll share this with the devs for consideration.
