Automix: Add Key Information of track currently playing
In IOS, BPM of current track is visible in automix mode but key is not visible. Would be helpful to manually rearrange subsequent tracks to support mixing in key.
Hi @turbopussy, thanks for the suggestion! I have forwarded this to the dev team for consideration. In the meantime, please note the following:
  1. In Automix Mode the Key for the upcoming songs is visible in the Library section while in portrait orientation.
  2. While in Automix, you can switch to Classic Mode and the Key is visible there.
  3. While in Automix, you can switch to Pro Mode and the Key is visible there.
I hope that helps!
Hi Slak_Jaw, yes, I know I can switch the mode but with just displaying the Key of the song currently playing that would not be necessary. At least when using the iPad there would be room for that additional information, eg above the key data of the subsequent track.
Understood. I have already passed this onto the dev team for consideration. Just thought those suggestions might help you in the meantime.
