Good day!
My automatic endpoints seem to be calculated wrong.
For a lot of tracks the entire last part is skipped, maybe automix thinks this is an outtro, but in fact these are still interesting parts that I would like to play. Also, this way the tracks get very short. The above is an extreme example, but a lot are like that. Maybe automix does not like my musical preference.
I thought to use the “use start and end points of song if available” option, but can’t figure out how that works. Are these cue points? If yes, how do I make a cue point a start or an end for automix? Naming them “start” and “end”? Maybe RTFM but I can’t find.
I also tried to temporarily switch off automix so that it plays the outtro and switch it on again at the point I would like to fade, but that does not work. Upon starting automix it loads a new track even if there is already one loaded. And it defies the concept, but would be a reasonable work-around for me until it gets improved.
Thanks! Best regards Bart.
