AUTOMIX CUTS OUT 10 sec of each song (mixing with the other) can you make those 10 second adjustable from 0 to 10?
I need to play whole songs. I love AUTOMIX. Unfortunately it cut out last 10 second of each song which make it useless for me.
It would be good if I could choose how many second before song ends Automix
starts mixing. If I choose zero or one second I should be fine.
I don’t think it will be big problem to update DJ 2 to do that.
I’m android user.
Hey there,
thank you for your idea.
At the moment this feature is not supported by djay for Android, but I forwarded your request internally and will keep you posted about any updates regarding this issue.
Hey there,
Hello everybody,
can one say in about if and when you can use the function “Trigger befor end” for the Android version?
Many Thanks!
