Hey all!
I want to use Automix on my DDJ 1000 SRT and I assume that’s in external mode.
Is that possible now? I think I read it was being worked on.
If not are there other controllers that I can buy that have this function?
Cheers
Hey all!
Cheers
Hi @Danny_The_Swedish_Mu, Automix only works when the djay mixer mode is set to internal. Most supported DJ controllers use internal mixer mode. A good example of this is the Reloop Mixon 8. Typically only DJ Mixers like the Pioneer DJM-S7 use external mixer mode. Here is the full list of currently supported hardware for djay Pro on iOS.
Thank you very much!
To not buy one that happens to not work with internal mode, could you please let me know which Pioneers do?
Cheers
You’re welcome @Danny_The_Swedish_Mu
Great! Does FLX10 work as well?
@Danny_The_Swedish_Mu the FLX10 is not currently officially supported, but you’ll find some non-official MIDI mappings on this forum if you search.
Hello everyone! I’m happy to report that Automix now supports External Mixer Mode devices in djay 5.3. For the full 5.3 release notes, please refer to the topic below. Thanks!
