djay 2 Pro for macOS’s automix feature (manually or automatically triggered) jumps ~10 seconds into the song instead of starting at the beginning, isn’t this a huge bug?
Hey Lucas, thanks for the quick reply! Hopefully the fix will be easy and fast
Going forward I’m hoping to also set start and end cue points for songs, so I plan to enable the “Use start and end point of song” checkbox. Hopefully both the " Automix Transition to Inactive Deck Button" and any other way that automix uses to transition to the next song will also take this into account.
Hey hey Edison. If you watch the video you can see I’ve set both start and end points of the song range to manual, 0 seconds.
Play around with the song range in auto mix, change it from automatic to manual and you can then start from 0 seconds or set Q-point/start point
thank you for pointing this out. The Automix Transition to Inactive Deck Button in the Automix view mode is not taking in the song range settings.
Good find
We will provide a fix as fast as possible.
Cheers,Lukas E.
