Automix for Open Format Dj's
YOUR SUGGESTION:
  1. The automix works quite well for house, and other formats that are not open format. I have noticed that for songs without a fixed drum intro that Automix can find, is there a way to either turn it off or switch for wedding or other dj’s that are open format. It can jump into a song past the entire first minute of the verse and that doesn’t work well if it can’t find a solid start.
    Thanks for any advice on how to fix a large library. I love the software but this is a hang up for me to go 100% in from my previous software.
Hi @Gold_Medal_Sound, welcome to the Community! I recommend that you set Automix Start and End points for your songs.
Once you done this, navigate to the Automix Settings and enable Use start and end point of song if available. I hope that helps!
