automix from one deck
hi all
i was thinking that it would be very useful if automix could be assigned to just one deck, leaving the others open requests or what not.
thank you for your post.
The problem here is the transition and pre analysation of the upcoming track.
Analysation needs some time and also continuous playing with the selected transition would not work with only one deck.
With djay Pro you can work around this in the 4 deck mode, which version are you using by the way?
Thank you for your follow up.
So have you tried using the Automix in the 4 deck mode?
I am using Pro on a Mac Pro
Hi Lukas,
I have not. Am I to infer that a work around is possible, using this path?
