Why does automix often drop just the second track in the playlist I load?
It loads and plays track 1 and then 3, track 2 just disappears and then everything else works fine…
Hi Julian,
Do you mean when you add the playlist to the Automix queue? This only happens when you start Automix and BOTH turntables are empty. This is a known issue and our developers are working on a solution. In the mean time, load songs on both decks before starting Automix. Or, simply add the same song twice (as 2nd and 3rd song).
good to know. weird bug.
I’ve just got DJAY 2 for my iPad Air and am also having this problem. Glad to see it is a known issue but not encouraging that it has been known about for a year and not yet fixed.
