Automix issue with DJ 2 on iphone
just started experiencing and issue. On some playlist in iTunes, not all, Automix just runs through them rapidly, so fast that nothing ever plays before the next track is loaded. Just keeps going through the playlist over and over.
can you please send us the Automix settings you are using?
Cheers,Lukas E.
Thank you for the follow up, settings dont look suspicious, can you send us an exemplary video of the explained behaviour via support@algoriddim.com?
Cheers,Lukas E.
Why are you ever using auto mix?? Seriously??
Lukas, What settings do you mean? Everything is default. Most of the playlist work fine, but some won’t do anything but rapidly cycle through each song. On another it just plays one of the songs on the playlist over and over, even though there are about 42 songs on the list. Everything used to work fine.
thanks for your help
i select a playlist from itunes, shuffle is off, transition is standard, 3 second duration, auto-sync is off, trigger before end is 10 seconds
